Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 10-10-2011, 03:32 PM
spidrman is on a distinguished road
Mazak VTC-300C Alarm 202
202 - Air pressure down on sensor of the traveler column.
During operation this alarm occurs and causes the machine to stall mid process. How do we fix this? So far none of the Mazak mechanics have been able to solve this problem. Please help!
Old 10-10-2011, 08:32 PM
paul3112 is on a distinguished road
logic of the issue
I have no previous experience with this machine of issue. That said it does get me thinking.
for the error to register ther must be a condition being acted upon;
can you fit a presure guage to the sensor at the column?
if good then is sensor output correct.
then is condition being reflected correctly at the i/o ( i am assuming ttl at the i/o ) (there is also a continuity check and voltage drop to be done on this cable)
then last of all is it poss to by-pass all of that and check the programme with a known input ( again assuming ttl so below 2.2 volts or above 2.7 volts) to replicate the fail state and if lucky a pass state.
As I said no previous experience here at all. just thinking aloud.
Good luck
Paul
Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!! Mill&Lathe Mazak, Mitsubishi, Mazatrol 15 10-06-2011 08:44 PM
problems MAHO 300c 1984 jeroen k Deckel, Maho, Aciera, Abene Mills 0 01-22-2011 09:21 AM
Need Help!- Mazak alarm Bala Mazak, Mitsubishi, Mazatrol 4 01-21-2011 04:48 AM
Maho MH 300C information request Dirkos Deckel, Maho, Aciera, Abene Mills 0 06-09-2010 01:58 AM
Mazak VTC-300C 212 Alarm? Cyre Mazak, Mitsubishi, Mazatrol 1 11-28-2007 11:06 AM
