| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
started machine up this morning and had a few different alarms first 2 was, 10 detector malfunction 2 emergency stop hit reset and got 72 servo warning 82spindle warning power off and power back on and got 2 new alarms 12 absolute postion warning 31 servo malfuction been waiting to here back from mazak. thought someboby may have an idea. thanks, chris 2 |
| For 31 servo malfunction please see the main Switch gear for servo is on or not because Since the electromagnetic switch OFF, command for the motor and servo system has been issued by activation of the emergency stop or door interlock function under CE machine specifications, the electromagnetic switches did not turn off within the required time. Also check the Drive Status healthy or Not. 12 absolute postion warning= for this see the Encoder/Pulse coder , Feed back cable and drive for any other help please free to communicate on prabhatmishra@gmx.com |
| The battery for the servo system that backs up the absolute position is getting low. 9f is a warning for that. Look for a unit called MDS-A-BT#. It will need to be replaced. The alarms you see on the ATC and MAG drives are normal. Until they receive a command to move they will display this alarm. |
| THANKS FOR THE HELP TALKED WITH MAZAK LATE YESTERDAY AND THEY TOLD ME THE SAME THING. I DIDN'T UNDERSTAND THEM CLEARLY BUT THINK THEY SAID WILL HAVE TO RESET MY HOME. IS THAT CORRET? GONING TO WAIT TILL THE BATTERY COMES IN AND CALL THEM BACK IF NEEDED. |
| Yes you will have to reset the home position. If I remember correctly it should be as easy as putting the machine in zero return mode and sending it home. Because all Mazak's have dog switches it should be pretty automatic (compared to other machines). |
| Mazak Nexus 510C II Probing | KTPDAN | Mazak, Mitsubishi, Mazatrol | 6 | 02-28-2011 12:29 PM |
| Need Help!- LOOKING FOR NEW HIGH QUALITY VMC IN NEXUS 510C CLASS | rmhydro | General Metal Working Machines | 0 | 12-20-2010 08:20 PM |
| Nexus 510c manuals | inioxos | Mazak, Mitsubishi, Mazatrol | 0 | 11-02-2010 04:23 PM |
| Need Help!- New 510C-II | paptep | Mazak, Mitsubishi, Mazatrol | 1 | 04-15-2008 02:27 PM |
| Measuring Probe Nexus 510C | Nine Blue | Mazak, Mitsubishi, Mazatrol | 13 | 04-07-2007 08:58 AM |
