Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 09-15-2011, 02:40 PM
Vezku is on a distinguished road
Alarm Z70:illegal abs, Mitsubishi Meldas M64 controller
Greetings,
we have a cnc-lathe with four axes. (two for regular x - z) and two for extra milling unit that has also x- and z- axis.
That milling unit uses dog- style positioning, so it dont have mechanical proximity sensor for reference return.
The servo motor connector had gone loose and now it has lost its positioning. When starting up the lathe, the error: "Z70 : illegal abs" lights on.
When trying to reference return the axis just keeps going, it cannot find it´s reference point.
The servo diagnostics says that the state is ZP-RTN, zero point returning.
I have been trying all the methods for the ABS home positioning, but they dont work. All the guides are for axis that has mechanical proximity sensors for reference positioning.
Can you help me on this one?
Is there a parameter that will zero the positioning data?
If someone would have Meldas 60/60s series parameter manual?
The control is Mitsubishi Meldas M64, 60/60s series. The servo is HA80NC-S.
THANKS!
Help w mitsubishi/meldas 500 Gpl625 General CNC (Mill and Lathe) Control Software (NC) 1 10-03-2011 11:27 PM
Mitsubishi Meldas LOB Servo OCP alarm Whiteforest Mazak, Mitsubishi, Mazatrol 3 06-02-2010 06:05 AM
Need Help!- 009 P/S ALARM (ILLEGAL ADDRESS INPUT) macrosat SolidCam 2 07-30-2009 01:38 AM
Running into memory issues Mitsubishi M-V60C - Meldas 300 Controller Josh Lehman Mazak, Mitsubishi, Mazatrol 22 03-07-2009 09:38 AM
Mitsubishi Meldas L1 LocTite98 General CNC (Mill and Lathe) Control Software (NC) 21 01-30-2008 01:26 PM
