| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hi guys. we're currently using mazak cnc lathe machine mazatrol pc fuzion 640T,until we encounter this kind of alarm.anyone know on how to eliminate this and what could be the cause? |
| It's definitely a problem with your servo system. One of your drives should be flashing alarm 43. If there is another amplifier/drive with the same model number (MDS-....) try to swap it. Make all the connections the same but make sure you swap the rotary switch settings between the drives (little blue switch behind a door towards the top of the drive). If the problem follows then it is in the drive. If it does not follow you may have a problem with the encoder as this is a feedback alarm. |
| Need Help!- Mazak Nexus 200 - Battery Malfunction Alarm | bluechipmfgllc | General Electronics Discussion | 1 | 09-27-2011 09:58 PM |
| Need Help!- Mazak T32-3 Alarm 015 System Malfunction | reillyeng | Mazak, Mitsubishi, Mazatrol | 8 | 05-27-2011 08:24 AM |
| 911 atc system busy alarm c help | mbm | Okuma | 2 | 08-03-2010 08:47 AM |
| PMC system alarm | dalvinder | Machine Problems, Solutions , Wireless DNC, serial port | 4 | 09-05-2007 08:28 PM |
| System Alarm # 3 | tedh | General CNC (Mill and Lathe) Control Software (NC) | 6 | 07-25-2005 05:12 PM |
