Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 09-14-2011, 04:26 PM
Karsue is on a distinguished road
Question Mazatrol T32-6 PLG C-Axis Sensor
Few days ago my C-Axis on my Multiplex 620 on Head 2 could not find reference position and was running without stoping.
I replaced PLG sensor and pre-amp with another one the result is that the spindle stop after referencing on c-axis but every time it is changing the position after referencing on C-Axis and on display it shows 0 but it is different han the last referencing.
Is there any recommendation or thought??? in case if some one knows this problem, Please advise me by that, I appreciate any information regarding this.
Many Thanks.
Old 09-25-2011, 08:38 PM
Rokkin is on a distinguished road
Sounds like an adjustment is needed on the pre-amp.
Old 09-26-2011, 01:30 PM
onthebumper is on a distinguished road
What kind of PLG is it? Do you have two gears with two sensors and a preamp board? Most T32's used this combination for C-axis and they are tricky to set up. You will need an ocsilliscope to adjust this type of PLG.
Old 09-26-2011, 09:11 PM
THERE ARE 2 GEARS, 2 SENSORS & A PRE-AMP.
I KNEW THAT I MIGHT NEED SCOPE BUT I WAS WISHING THAT IF THERE IS ANOTHER AWAY TO ADJUST IT.
ANY WAY THANK YOU ALL.
Touch Sensor Z Axis? Ezra Joes CNC Model 2006 4 12-14-2010 02:03 PM
Mazatrol program B-axis help CNCRim Mazak, Mitsubishi, Mazatrol 3 05-03-2010 08:20 PM
Need Help!- J325 Z axis proximity sensor ??? lavrgs Tree 10 08-31-2009 10:36 AM
Need Help!- Axis movement speed adjusted by pressure sensor Viesturs Controller & Computer Solutions 0 05-20-2009 06:44 AM
Z-Axis depth guide sensor ? deleteallusers Mechanical Calculations/Engineering Design 5 07-17-2007 12:38 AM
