| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hey guy everyonce and a while, the controls for my mazak go dead... in this case, did tool change, was using the hand wheel for about 5 min, turned it off and went to use it again and nothing, machine doesnt move at all, not in rapid, home, jog, handwheel, MDI, Auto... nothing. Looking at the Mitsubishi PLC servo drives, these are the sequence of what I assume are error codes, below are what I see on the LED screen when the machine is running normally... far left drive - MDS-C1-V1-10 - F4/E7/F4/E7/OFF/REPEAT/etc. Runs with C1 in LED screen middle drive - MDSC1V2-3520S - F1/E7/F2/E7/OFF/REPEAT/etc. Runs with d1/d2 in LED screen right drive - MDS-C1-V1-45S - F3/E7/F3/E7/OFF/REPEAT/etc. runs with d3 in LED screen spindle drive - MDS-CA-SP-300 - F5/E7/F5/E7/OFF/REPEAT/etc. Runs with C5 in LED screen Any insight as to what my machine is "doing" or what i may be doing to cause my drives to stop working and show error codes, would be much appreciated.. could it be the batteries? It does it every now and then, boss claiming it never happened to him when he was running the machine, so im not sure what exactly is going on... The only way to clear it is to shut the machine off, home it, and resume working, but as far as im concerned i shouldn't have to... thanks guy Also if its anything, it also has 4th axis.. |
We had this issue on 2 of these machines. We found that when you put the remote handwheel back on the machine the magents cause it to slap on causing a partial e-stop. To correct this press the e-stop on the remote hand wheel and reset it. Then hold MF1 and reset at the same time till the machine comes out of e-stop. We had both of the remote hand wheels replaced and still the same problem. Just got to be gental putting the remote back on the machine. |
Thanks! I had looked up the error codes for the Servo drives in the Mitsubishi site, and said majority of them have to do with being in an "emergency state" which i assume had something to do with the POS E-Stop on the handwheel... I was gunna try hitting the E-stop then reset and such next time i did it, but I appreciate the input! thanks again! figured I wasnt the first on here for it to happen to haha |
| CNC controls | MBG | CNC Plasma and Waterjet Machines | 2 | 11-12-2010 04:57 PM |
| Build Thread- From SX3 controls to X4 | PEU | Syil Products | 6 | 03-25-2010 12:22 PM |
| PC Controls vs. Industrial Controls | Billiam | General CNC (Mill and Lathe) Control Software (NC) | 0 | 03-16-2009 08:54 AM |
| Jog Controls | dafowfidy | Mach Mill | 2 | 03-21-2007 04:01 PM |
| Controls | Chuck Pool | General CNC (Mill and Lathe) Control Software (NC) | 7 | 02-23-2006 11:49 AM |
