Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-26-2011, 03:10 AM
38mopar_fan is on a distinguished road
Unhappy MAZAK sqt 15my Tplus controler
Machine has had an intermittant problem for some time. Sometimes it will not power up. If ledt for 15mins with fans going then switched off and on again it would fire up fine. For the last couple of weeks it was useable somes time it would fire up from cold, used for a couple of hours then switched off. When switched on 30mins later would not fire up and had to use the same procedure again. Now it will not fire up at all and three of the four small drives show "Ab" and the fourth one only "b" When start button activated the three drives that showed Ab now flash 'F6E7, F5E7", and one "F1E7and F2E7"
After switching on and off a few times the three drives "Ab" 4th drive always shows "b" only
Any assistance is appreciated.
Been waiting for over three weeks for agent who sold the machine new to have a look at it
Old 08-29-2011, 06:46 PM
mantenim's Avatar
mantenim is on a distinguished road
what alarm the mazatrol show?
E7: CNC emergency stop, no problem in the drive.
Old 09-01-2011, 03:50 PM
The maztrol is blank as the start precess stops with the drive alarms
this thing will not go past these alarms
Cheers
Peter
Problem- no z moves in mazak tplus tsaladyga Mastercam 2 01-06-2010 10:37 PM
mazak 16 c 32 b controler gosserwb Mazak, Mitsubishi, Mazatrol 2 04-05-2007 03:17 PM
mazak 32 controler gosserwb Mazak, Mitsubishi, Mazatrol 4 02-14-2007 06:53 PM
mazak 32 controler gosserwb Mazak, Mitsubishi, Mazatrol 2 02-11-2007 03:55 PM
mazak tplus radavis321 Mazak, Mitsubishi, Mazatrol 0 01-25-2007 03:51 AM
