Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 08-06-2011, 12:43 PM
rajesh_1355 is on a distinguished road
ECOCA - MELDAS MAGIC 64L
ALARM: EMERGENCY EXIN
M01 OPERATION ERROR XZ
Detail of machine are as under,
NC - MELDAS MAGIC 64L
PC - MAGIC Pro-HI/L ( INTL) BDD - A02 W016 - A0
PLC - ECOCA - ELALL - M5
SYSTEM ID - 2090745880
In this machine, system power supply gone bad. We replaced the supply , now we are facing following alarms,
EMERGENCY EXIN
According to the electrical diagram, hard over travel switches are optional & are missing in machine.
In diagnosis mode, checked other inputs like cycle start , mode change switch which are ok.
Surprisingly no any out put is being generated.
Tried to check the PLC ladder but it is not being open. When searched any input like X29 or similar it shows ERROR.
When tried to check PLC size it shows
LINK 0 / KBYTE
LADDER 0 / KB
MESSAGE 0/ KB
I loaded all data by floppy even then it shows the same alarm. ( path c:/ncbac )
Next Day Work:
To-day I reloaded all the data, but still no improvement & same alarm is being displayed.
In Meldas Magic screen tried to open the PLC ladder.
Sequence ... Ctr + F , Menu , 9main, monitor , NO / NC , X1F & enter it shows Prog not found.
When I tried to search by Rung No. 100,
PLC ladder is being displayed but when I checked whole ladder, no any X or Y contact was found.
I am quite confused, pl help.
In seven segment display of controller it shows " A "
( Can we load the data with the help of RS232 port.)
PL send your suggestion to solve the problem..
Need Help!- Mitsubishi Magic 64 software. GPena Mazak, Mitsubishi, Mazatrol 0 05-25-2011 05:04 PM
Magic Smoke! awerby Gecko Drives 7 04-14-2011 09:06 PM
Didn't let the magic blue smoke out yet..... Edster Fadal 7 01-26-2010 10:09 AM
MITSUBISHI MAGIC 64 CHANDRU Mazak, Mitsubishi, Mazatrol 0 05-10-2009 10:35 AM
Need to refil the magic smoke runnoahrun General Electronics Discussion 0 11-30-2005 11:20 PM
