Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-25-2011, 06:28 PM
kbat is on a distinguished road
Newbie on Mazak Lathe,need help with Programming
Looking for a way to write a program for multiple part-offs, but looking at doing it thru a sub program or macro. The 2 operations are face and chamfer od, then using part off tool to chamfer backside then part-off. By using a macro or subs I would like to be able to change one varaible number as to how many parts id like to run at a time. A generic setup of a prog would be appreciated. Im just having trouble with the g codes and setup of program.
Thanx,
Kbat
Old 07-25-2011, 07:46 PM
BOATDUDEGUY's Avatar
BOATDUDEGUY is on a distinguished road
IT ISNT CONVERSATIONAL? I THOUGHT THEY ALL WERE
Old 08-01-2011, 05:51 PM
tds11223 is on a distinguished road
Instead of a macro, use the mazatrol program and adjust settings at bottom of program for # of parts to cut off. I find this to be easier than writing a macro.
Mazak programming tikj Mazak, Mitsubishi, Mazatrol 2 12-08-2011 01:00 PM
Mazak m32 programming in the x, z plane? MazakAJV Mazak, Mitsubishi, Mazatrol 1 04-15-2011 03:18 PM
EIA/ISO programming Mazak AJV MazakAJV Mazak, Mitsubishi, Mazatrol 2 03-17-2011 06:28 PM
Mazak programming question chrisryn Mazak, Mitsubishi, Mazatrol 21 02-16-2011 09:32 AM
Mazak T2 Programming Help newbi100 General CNC (Mill and Lathe) Control Software (NC) 2 01-05-2010 03:05 PM
