| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hello Everyone, I'm programming in Mazatrol (T32-3) and it's a very simple part, basically just an internally threaded insert. I have a Q(.332") drill bit in a live tooling holder and I'm using it to simply drill through the centerline of the part. The issue I'm running into is that the bit will start to drill, catch on a chip and begin to rotate with the spindle. The collet is plenty tight, it's just the live tooling holder is turning with the main spindle. I tried using an M211 to lock the C-axis but that froze the program as soon as it got to that line of code. Is there a way to lock the C-Axis spindle or should I just be using a rigid (non-live tooling) holder? Thanks, Dan |
| There is an M code to lock the c axis. However, it is bad machining practice to machine on the Centerline of a C axis with live tooling unless you are rotating the C axis and the live tooling. Mazatrol does not offer a unit allowing both the c axis and live tooling to be rotated at the same time. You would need to program in an EIA format or Manual unit. I would simply call the tool a T-drill and do not use live tooling. |
| new ST20 any opinions?? | gixxergary | Haas Lathes | 8 | 05-11-2011 03:10 PM |
| Need Help!- Spot Drilling/Center Drilling Steel 55 HRC | JWB_Machining | General Metalwork Discussion | 7 | 03-11-2009 01:35 PM |
| mazak operations | kparthis | Mazak, Mitsubishi, Mazatrol | 2 | 07-20-2007 08:25 PM |
| operations comments | salem | General CNC (Mill and Lathe) Control Software (NC) | 1 | 09-02-2006 08:20 AM |
