Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-11-2011, 05:18 AM
blox7 is on a distinguished road
tool change
Hi I am trying to get a mazak turning machine with a 640T control to automatically adjust the tool change position in the Z direction in accordance with the longest tool in the turret i.e. read the length of the longest tool and add approx 10" so that the turret can index without any possibility of hitting the chuck or job. We are programming in ISO format not mazatrol. I would greatly appreciate any help and an example program of what I need.
Regards JB.
Old 08-01-2011, 05:54 PM
tds11223 is on a distinguished road
you can set up G30 to perform a tool change wherever you want.
I suggest instead of that check your user parameters. There is a parameter that allows you to perform tool changes by using clearance from the largest tool length in the tool data.
Problem- 21iT: Using 2 offsets for 1 tool:Machine stops for tool change gnmachine Fanuc 4 02-01-2011 08:10 AM
need help wana make macro for getting tool change by giving tool pot no on vmc instea ghevari Parametric Programing 0 02-14-2010 12:26 PM
orient tool for tool change Hall effect? Luslugger CNC Machining Centers 0 04-24-2009 06:24 PM
Very slow tool change on Tool Room Mill Capt Crunch Haas Mills 3 12-21-2007 12:20 PM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
