Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 07-06-2011, 08:10 AM
gearmachinist is on a distinguished road
Mazatrol T32-2J Bus Error
We have a Mazak QT8 CNC Lathe that we recently purchased and has probably been in storage for some time now. When I first powered up the machine the control gave a title screen that said Mazatrol T32-2J. In the upper left hand corner in small letters it gave a Bus Error , Error at or near $00493096.
This morning I powered the machine up and it appears to have the usual Mazatrol screen but we get no response from the control. The hydraulic pump does not come on and nothing operates.
The control is a FCA 325L2NJ-1. On board MC116, we have 2 red and 2 green led's (Top red, 2nd and 3rd green, 4th red, 5th off). On MC616 the first 2 led's are red and bottom 2 are off. On MC712, the bottom LED flashes green.
Would anyone have an idea as to what is going on with this control and what should we do at this point? Is the memory lost on the control and should we perform a memory clear and re-initialization on the control or do we have a deeper problem?
Thank you,
Gary
Old 09-13-2011, 01:22 PM
BAUMACH is on a distinguished road
Having same alarm (Bus Error). Did you ever find out what was the cause?
Mazatrol M-2 Error 367 ReePMM Mazak, Mitsubishi, Mazatrol 1 09-14-2010 12:39 PM
Mazatrol WPC Error dynalowrider200 Mazak, Mitsubishi, Mazatrol 2 02-14-2010 06:02 PM
Problem- mazatrol m32 FLD Error M42 Mazak, Mitsubishi, Mazatrol 25 12-10-2009 01:12 AM
mazatrol m-2 sum check error bishop world Mazak, Mitsubishi, Mazatrol 2 06-26-2007 06:05 PM
mazatrol pc-fusion 640 error.... monkei Mazak, Mitsubishi, Mazatrol 3 06-02-2006 06:42 PM
