Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-30-2011, 07:02 AM
Hoosier Bird is on a distinguished road
Mazatrol Fusion 640t Nexus 250 my
I am trying to c-axis mill a sprocket using eia programmed from mastercam. This is our first attempt at programming the lathe using mastercam. Looks good on the graphics but as I'm walking around the sprocket the C-axis is taking the longest route to get there. So instead of moving the C-axis only 2 degrees it is running 358 degrees which wipes out all the teeth. Not sure if there is a code that I need in my program to tell it to always take the shortest route......Please help
Old 06-30-2011, 08:11 AM
Never mind. Changed the M201 to M200 and it works great.
Old 06-30-2011, 09:16 AM
I was wrong.....it's still doing the same thing.......
Need Help!- Mazatrol Dual Turn Fusion 640T (Door lock question) Sammeh Mazak, Mitsubishi, Mazatrol 3 12-22-2010 09:06 AM
pc fusion 640t strecha Mazak, Mitsubishi, Mazatrol 0 11-08-2008 10:00 AM
640t nexus chip conveyor Lost-one Mazak, Mitsubishi, Mazatrol 1 03-11-2008 11:27 AM
Mazak Nexus QTN 640T chattwo Mazak, Mitsubishi, Mazatrol 1 09-21-2007 07:58 AM
Mazak quick turn nexus 250ms 640t control sidecar82 Mazak, Mitsubishi, Mazatrol 8 04-04-2007 07:07 PM
