Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-23-2011, 12:43 PM
Emmel is on a distinguished road
Mitsubishi Parts
Model : VMC – 850
Series no : 871241
MFG Date : 5 – 99
Voltage : 380v
I need 2 of these motors complete to buy
Motor specifications
HA100NC-S Mitsubishi ac servo motor
Output 2kw cont iec341 1994
Volt 170v Amp 10A
Freq 66,7 HZ Speed 2000r/min
Perm mag Field 200v inverter
Max torque 42nm 42A
Manual number Z653414
Spec no 87037 date 98-7
Emmel
Tel +27 838811280
emmel@mweb.co.za
Old 06-25-2011, 11:15 PM
TANKER is on a distinguished road
need help
I have a 1999 mazak M4 cnc lathe with a mazatrol T plus control.
I am geting a alarm # 200 and the hyd. pump will not run.
If i manually close the relay the pump will run and all of resets are good
Parts for 4th Axis Mitsubishi Meldus MVO-0 140jodel Mazak, Mitsubishi, Mazatrol 1 05-03-2011 10:25 AM
Parts fitting clearances in acrylic and aluminum parts? jbarber General Material Machining Solutions 0 11-11-2010 09:52 PM
Pneumatic parts catcher moving too jerky: small parts can shake out MadMax Daewoo/Doosan 4 12-14-2009 05:13 PM
Arboga G2508 Parts, Parts List, Manual omnimfg Want To Buy...Need help! 0 04-03-2009 11:59 AM
Sodick A 350 need parts or parts machine Please!! deckeldoctor EDM Machines 1 12-10-2008 07:08 PM
