Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-22-2011, 01:47 AM
Karsue is on a distinguished road
Unhappy M32/H500/Alarm:323 pallet changer error operation
The machine was stopped at the end of program by changing pallet No.:2 with No.:1 (To put Back Pallet No.:2) and there was no alarm.
The machine does not unclamp the table and also there is no error but if I want to unload pallet No.:2 manually, the error alarm "323 pallet changer mis. operation" appears.
All the axis are in 2nd reference position, all the proximity switches are OK, there is no mechanical problem.
May be 1 signal is not avaiable but which one??? or PLC does not communicate properly???
Incase if there is any recommendation or help, please let me know.
Thanks.
Old 07-07-2011, 01:06 PM
botha.y is on a distinguished road
This
This is nearly impossible to tell from the info you have given. Check for pallet operations and see at which stage exactly you get your clamp, there are usually arms motions (extend, retract, go down, go up) associated with pallet transfers. Cheers.
vf3 ss pallet changer mayhem Haas Mills 2 04-25-2011 04:45 PM
HAAS Pallet changer alarm horst007 Haas Mills 2 02-18-2011 09:04 AM
Need Help!- J/C unit alarm (pallet changer) padobranac Fanuc 2 09-25-2008 02:28 PM
Pallet Changer MIDDEN300 CNC Machining Centers 5 09-20-2008 08:32 AM
FH 5800 pallet changer driver alarm sting_dot Mazak, Mitsubishi, Mazatrol 4 10-29-2007 10:59 AM
