Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 06-21-2011, 09:35 AM
1234567 is on a distinguished road
m codes
does anybody have a m code list for a h-400n with a m32 control?Or what the pallet change m code might be?
Old 06-21-2011, 10:03 AM
camsys is on a distinguished road
You can look at the attached M32 machining center Mcode list, I don't
know if it applies to you model, but it's worth a try.
Old 06-22-2011, 03:10 PM
botha.y is on a distinguished road
Mitsubishi M-codes
M-codes are actually set by the ladder designer. Check your ladder and you will be able to see the function of each of them (except M98 and M99 I think). Cheers.
Botha
Need Help!- G codes and M codes for Mazak Quick Turn T-2 sauli Mazak, Mitsubishi, Mazatrol 0 05-23-2011 11:22 AM
G codes M codes Mach3 eaglezsoar Mach Software (ArtSoft software) 2 02-03-2011 05:38 PM
Need Help!- Need full list of G CODES AND M CODES FOR FANUC 21I SonnyTees.com G-Code Programing 3 02-23-2010 10:27 AM
Need Help!- M CODES AND G52 fenix728 G-Code Programing 2 11-17-2008 08:03 PM
M-codes and G-codes 4 Matsuura ES-1000V maximusek G-Code Programing 2 11-27-2007 06:41 AM
