Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-31-2011, 08:33 AM
rob low is on a distinguished road
thread milling mazatrol
Hi, Can anyone assist with a thread milling example program for putting threaded holes on a pcd on the face of a part, Machine is an integrex 640MT PRO
I would like to use Mazatrol if possible? eg 150 mm pcd with 8 off equally spaced 12mm thread with 1.75mm pitch
Old 06-01-2011, 07:32 AM
Its ok thanks, now sorted using "Circ Mill" option 1 for "Tornado" Set pitch 1 to zero & set pitch 2 to the pitch ie 1.75mm, Set dia to the major of tap = 12mm
Need Help!- drilling and thread M16 Bobcam and Mazatrol M-2 sve0019 General CAM Discussion 2 10-13-2010 11:27 AM
mazatrol thread milling cr500 Mazak, Mitsubishi, Mazatrol 7 04-13-2009 08:48 AM
Problem- thread milling in nexus using mazatrol uperez Mazak, Mitsubishi, Mazatrol 2 03-31-2009 03:06 PM
Mazatrol variable thread lead? extanker59 Mazak, Mitsubishi, Mazatrol 0 06-24-2008 01:24 PM
Mazatrol T Plus thread cycle in synch? Castle1 Mazak, Mitsubishi, Mazatrol 2 03-25-2007 10:22 PM
