Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 05-07-2011, 12:12 PM
Manuseymour is on a distinguished road
Mazak QT-20 spindle inhibit alarm
Hi everyone. Have just purchased a Mazak QT-20 with mazatrol T1 control. Having a problem getting the spindle to run. Keeps throwing up the alarm 130 spindle rotation inhibited. I can get the spindle to jog but it will not allow me to put the spindle on by simply upping the RPM. Also when I try to run a program it won't start the spindle and just says missing condition. Have huge experience programming and operating mazaks but am stumped on this one. Any help would be greatly appreciated. Iv tried moving the chuck to engage the gears. Tried lots of other things but can't get it to do more than a jog. Please help. Lol.
Old 05-07-2011, 12:35 PM
Sorry machine is 1983 and second hand obviously. Had a new spindle put in about a year ago and all was working fine prior to transportation to myself. Bit more info there.
Old 05-10-2011, 02:54 AM
southern cnc is on a distinguished road
The only two things that I can remember that would cause this is the chuck position (closed or open, internal or external chucking) and the tailstock position. There are probably two proximity switches in the body of the tailstock. You probably already know this, but maybe it will help.
Good luck.
Old 05-10-2011, 03:37 PM
ITT-Student is on a distinguished road
The machine was moved as you said and any number of things could have been jarred loose such as limit switches, etc... wiring loose or broken.
Old 05-13-2011, 08:49 AM
chippy1 is on a distinguished road
Also check to see if there is a gear selection. If it thinks it is not in gear then you will get this alarm too.
Regards,
Chippy
Old 05-13-2011, 04:31 PM
Leelund is on a distinguished road
AIR! If I recall they had air chucks installed on them. Gotta have air on to the machine and the pressure switch made.
Old 05-13-2011, 06:09 PM
gridley51 is on a distinguished road
Where in Scotland are you?
Mark.
Tags
mazak alarm 130, mazak qt-20, mazak spindle problems
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
SL35 Spindle Inhibit in Jog dmh007 Mori lathes 5 08-26-2010 05:22 PM
Need Help!- Mazak Mazatrol Control M1 -- Spindle Alarm stephen21in Mazak, Mitsubishi, Mazatrol 7 03-18-2009 08:46 AM
Problem- Inhibit spindle alarm bigbobr Fadal 1 02-15-2008 11:38 AM
Inhibit vs phase chopping stragenmitsuko Open Source Controller Boards 0 02-02-2008 11:18 AM
