| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hi I have a mazak 610 with two heads, with maztrol 32-6 controller, Actually is not working because an alarm 28 PRINT CIRCUIT BOARD MALFUNCTIONING appers and I can not reset it, someone knows how ti fix it, thanks. |
| if you are getting this alarm, it probably means you are getting some type of alarm on one of your drives. the most common one for this is a 17 on the Spindle drive. sine this a 32 controller (not sure wether mill or lathe) it will probably have a FR-SF drive, the board that causes the 17 on the drive (28 on the NC screen) is usually the SF-CA card. you could check your voltages on this board, also try taking the board off make sure on the contacts on the top are ok. another thing on the SF-CA card there are test pins. one is labeled CH1 check to make sure you have 5VDC. |
| Need Help!- Mazak M-32 Download Problem | snavman | Mazak, Mitsubishi, Mazatrol | 1 | 05-21-2009 09:31 PM |
| Mazak VTC 41 memory problem | kamran67 | Mazak, Mitsubishi, Mazatrol | 2 | 09-07-2008 06:57 AM |
| Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem | sting_dot | Mazak, Mitsubishi, Mazatrol | 0 | 05-21-2007 08:20 PM |
| CMT problem mazak t32-2 | Enda | Mazak, Mitsubishi, Mazatrol | 1 | 02-09-2006 03:19 PM |
