Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 04-30-2011, 07:05 AM
sve0019 is on a distinguished road
Batterie problem and parameters Mazatrol Cam M-2
I have a new problem now with my Mazak VQC 20/40B Mazatrol Cam M-2.
First se my tread on Mazak VQC20/40B Mazatrol Cam M-2. Alarm 22 and 23 batterie low, parameters wrong.
To get knowlidge whot happends so far and whot I did.,after that everything worked well And I was very happy,but not for so long,A week later then starting
machine again it gives alarm 23 and 22,I was checking parameters and it was a mes.,then i know i was back on point one again.I taked the batterie
out of card FX784-8,the one there bat led wos lightening and checked it,now I have only 0.5 volts and about 30 ma,far low..Normal it shoud bee
3.6 volts and unleast 200 ma.I was ordered a new batterie again the exakt same type from MDS batteries UK .Part type nr V200H-3ME.Before I pot it
on place checked it and find it was in wery good condition,now I was starting machine and repeting the procedures I descripted in link abowe,every
thing was up and running.However after 2 days alarms was back aswell as bad parameters.I know by now I shoud change the FX784-8 card becouse
its clear something on it is wrong.
THE Question to all professionals on Cnczone is.
I woud like if somebody know if the 5 volts coming from powersupply is regulated down to 3.6 volts on the FX784-8 card only,and in that case can tell
me whot components is involved in the steps.For sure beside batterie is a backup capacitor,but is there aswell a resistor and some diods,maybee
transistors?Maybe something else.
By the way is there some having a FX784-8 technical sheme you know the one with all chips transistors resistors condensators and so on.
Sve0019
ThankYou.
In advance.
Mazak VQC20/40B Mazatrol Cam M-2. Alarm 22 and 23 batterie low, parameters wrong. sve0019 Mazak, Mitsubishi, Mazatrol 0 04-05-2011 02:12 AM
Problem- Mazatrol M2 parameters pcreek Mazak, Mitsubishi, Mazatrol 5 02-17-2011 10:50 AM
Mazatrol CAM T4 parameters ap-machine Mazak, Mitsubishi, Mazatrol 2 09-05-2008 01:19 PM
Mazatrol T1 communication parameters? sinjin341 Mazak, Mitsubishi, Mazatrol 3 07-22-2008 03:35 PM
Parameters list for Mazatrol M2 kotten1 Mazak, Mitsubishi, Mazatrol 1 06-17-2008 02:10 PM
