| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
I'm currently running a Mazak h-630 and it has a probe. Is it possible to use it like the newer machines by writing a small macro program or something to measure 3 points of the bore and tell me what size it is? The bore is about 14" Any help would be appreciated! Thanks, Tim |
| Do you have EIA software like Inpspection Plus or anything on the machine? or you trying to (or have to) use Mazatrol? ... and which control is on your machine?
__________________ It's just a part..... cutter still goes round and round.... |
| If I remember right, I don't think you can measure a 3 point bore on M32 (haven't had one of those around in many years). But you can rotate a 4 point bore cycle by changing the theta. Can you do it that way? you can also "cheat" this a bit by using the pocket or web cycle simply by changing the probing location in the bore if you have features of doing this normally. What you're doing here is measuring each axis off center of the bore to clear whatever you're trying to clear. Kind of like 'edge finding' a bore...
| Need Help!- MAZAK /RENISHAW PROBE | Nexus700D | Mazak, Mitsubishi, Mazatrol | 6 | 06-24-2010 03:07 AM |
| Need Help!- Probe sub program | Doranie | General CNC (Mill and Lathe) Control Software (NC) | 0 | 04-28-2010 10:40 AM |
| Need Help!- Mazak pc fusion probe issue | noPROBElem | Mazak, Mitsubishi, Mazatrol | 5 | 02-21-2009 08:01 PM |
| Probe Program | racear*2865 | Mach Mill | 8 | 12-01-2007 04:25 AM |
| Probe sub program | Graphcon | General CNC (Mill and Lathe) Control Software (NC) | 3 | 04-14-2005 06:56 AM |
