What mode are your feedrates in? (as in G94 or G93?)
Also, you're AccDec parameters may need some adjusting for G61.1.... what's your code like?
Since the code may be very short and in large quantity from that type of programming, you'll probably have better luck going into G5 mode (use it with G61.1). Also, do you have Cutting Level Select option on this machine?
Dynamic Offset is awesome for 5X machines (other control and machine buiders included) it's not going to change they way your high speed cutting is behaving right not. Dynamic Comp is a coordinate issue... not a speed issue.
LinkBack URL
About LinkBacks
