Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-12-2011, 02:52 PM
MazakAJV is on a distinguished road
EIA/ISO programming Mazak AJV
How do you start an EIA program with a Mazak. I am trying to program a 1/8-27 npt thread mill. Here is the program I need to input into the machine.Any ideas, will this even work?
program 27npt
O151
( FANUC I&J, RH, CLIMB, INTERNAL THREAD MILLING )
( TOOL - MT0250C04 27NPT )
( THREAD - 27 TPI, DIAMETER 0.403 INCH, DEPTH 0.264 INCH )
( TOOL RADIUS COMPENSATION D1=0 )
N1 T1 M06
G90 G00 G54 G40 G17 G94 X0.0000 Y0.0000 S1504 M03
G43 H1 Z1.9685 M08
( PASS NUMBER - 1 )
G90 G01 Z-0.2686 F196.9
G91 G01 G41 D1 X0.0318 Y-0.0318 F3.2
G03 X0.0318 Y0.0318 Z0.0046 I0.0000 J0.0318 F1.2
G03 X-0.0637 Y0.0639 Z0.0093 I-0.0639 J0.0000
G03 X-0.0642 Y-0.0639 Z0.0093 I0.0000 J-0.0642
G03 X0.0642 Y-0.0645 Z0.0093 I0.0645 J0.0000
G03 X0.0648 Y0.0645 Z0.0093 I0.0000 J0.0648
G03 X-0.0324 Y0.0324 Z0.0046 I-0.0324 J0.0000
G01 G40 X-0.0324 Y-0.0324 F196.9
( PASS NUMBER - 2 )
G91 G01 G41 D1 X0.0341 Y-0.0341 F3.2
G03 X0.0341 Y0.0341 Z0.0046 I0.0000 J0.0341 F1.2
G03 X-0.0683 Y0.0686 Z0.0093 I-0.0686 J0.0000
G03 X-0.0689 Y-0.0686 Z0.0093 I0.0000 J-0.0689
G03 X0.0689 Y-0.0691 Z0.0093 I0.0691 J0.0000
G03 X0.0694 Y0.0691 Z0.0093 I0.0000 J0.0694
G03 X-0.0347 Y0.0347 Z0.0046 I-0.0347 J0.0000
G01 G40 X-0.0347 Y-0.0347 F196.9
G90 G00 Z1.9685
M30
Old 03-16-2011, 05:32 PM
jimiscnc is on a distinguished road
% on a mazatrol does not work the same way as a fanuc.
On mazatrol it can only mean end of program and rewind. on a fanuc i think the first % means start of record and the second % means end of record.
-jim
Old 03-17-2011, 06:28 PM
I soon relized that after my post. It and I think each line requires you to put an eob after it. Thanks for replying.
Mazak programming tikj Mazak, Mitsubishi, Mazatrol 2 12-08-2011 01:00 PM
Mazak programming question chrisryn Mazak, Mitsubishi, Mazatrol 21 02-16-2011 09:32 AM
Mazak T2 Programming Help newbi100 General CNC (Mill and Lathe) Control Software (NC) 2 01-05-2010 03:05 PM
Need Help!- CAM packages for Mazak/Mazatrol programming? shape Mazak, Mitsubishi, Mazatrol 3 12-19-2008 09:02 PM
Mazak C axis programming dpinson General Metal Working Machines 1 07-02-2005 03:06 PM
