Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-12-2011, 09:40 AM
Admiron is on a distinguished road
Mazak 640 fussion software error
Hello
I have a Mazak 640 and this is working with win95. The unit start normal, but from time to time i become an error on the screen:
T64atmain
This program has performed an illegal operation and will be shut down.
I have see this problem in another threat but this was not helpfull, we dont have a another unit ore a system disk. Is there a backup from this program on the hard disk ? If yes, how can i reinstall this program ?
Old 03-12-2011, 10:38 AM
psychomill is on a distinguished road
No. You'll have to contact Mitsubishi or Mazak for another hard drive. Can't get the software reloaded like that.
Something to try though is you can have Mazak reinstall or update the Main A/B software and see if that works. But, if you're problem is with the OS or Mazatrol OS, need a new drive. Back up all your data now before you run into further problems.
It's just a part..... cutter still goes round and round....
Old 03-12-2011, 10:56 AM
Thanks for your answer. How can i make a update from the the main A/B software ?
Old 03-12-2011, 08:46 PM
You'll need Mazak to help with that ....
Old 03-13-2011, 10:22 PM
girishdk is on a distinguished road
Thumbs up 640 fussion software error
When this error window pops up, you can check the program name for which this error happens.
Depending on this program name & your observations(if it appears after a particular command or so), it will be possible to decide, if it is event driven or erratic.
If it is a OS related problem & if you have a similar machine, it is possible to reload OS from Norton Ghost.
If it is related to NC s/w, the setup files are normally available in NCBACKUP folder. In initial installation screen, you can cross check the s/w version of this setup file(before selecting CONTINUE menu).
Regards,
Girish
Old 03-15-2011, 01:13 PM
mantenim's Avatar
mantenim is on a distinguished road
close maztrol
uninstaling mazatrol
turn off (shut down)
turn on, only star windows.
re-instaling mazatrol (mcbackup, disk1, )
Old 03-23-2011, 08:58 PM
cnc doc is on a distinguished road
often the porblems are corrupt files in windows which is one thing i hate about pc based controls we all know how much trouble our pc's give us at home and yet we put them on machines. if you have not already ghosted your hard drive do it immediatly incase of a major failure. problem is though if your using windows 95 nt then you really need nt to ghost with. if you ghost and older operating system on windows 7 it will not work not sure why but know from experience on mazak and cincinati.
Need Help!- Mazak QT-20 HP Spindle Error Carnedude Mazak, Mitsubishi, Mazatrol 1 10-15-2010 10:29 AM
Need Help!- Mazak CAM T4 parameters error winds1sj Mazak, Mitsubishi, Mazatrol 0 06-09-2010 02:59 PM
Need Help!- Mazak Vqc 20/40B error massage evrgrecnc Mazak, Mitsubishi, Mazatrol 5 05-07-2010 03:57 AM
Mazak QT-6T Program Error flomatic Mazak, Mitsubishi, Mazatrol 4 04-07-2010 11:10 AM
Mazak VTC20 error ZipSnipe Mazak, Mitsubishi, Mazatrol 1 09-22-2006 11:46 AM
