Results 1 to 4 of 4
Thread: MAZAK FH6800's Parameters for Tool Lenght measurement system
    Aug 2010
    South Africa
    Hi all, I have a mazak machine Fh6800 for which i need to know the parameters related to the tool length measurement system, specially for its position. I am facing a problem in the length of tool measured by this system (measurement came 5.5 mm shorter than actual length)
    Registered mantenim's Avatar
    Sep 2008
    Mexico
    i hava a procedure with drawings
    i can send it to you by e mail
    a) Mount a sharp-pointed tool to the spindle.
    b) Extend the measuring unit.
    c) Align the center of a tool with the center of the plunger, and then input
    the machine coordinate values of the X- and Y-axes displayed on the POSITION
    screen to the parameter R2398 (X axis) and R2396 (Y axis) respectively.
    (Enter negative values without a decimal point when inputting to the
    parameter. Unit: 0.001 mm)
    * Operating procedure
    c)-1. Select the DIAGNOS display.
    c)-2. Select the VERSION display.
    c)-3. Select the DIAGNOS MONITOR display.
    c)-4. Move a cursor to the address position under the I/O MONITOR
    WRITE using a cursor key, and enter the parameter numbers using the
    address/numeric data keys on the operation panel, then press the
    INPUT key. The address is highlighted in red. (The figure below
    shows that R2398 is input to the address.)
    c)-5. When a cursor is moved to the position indicated by a red
    arrow, it is reversed to white as shown below.
    c)-6. Press the LONG key.
    c)-7. Enter the machine coordinate values of the X- and Y-axes
    displayed on the POSITION screen using the numeric day keys. (Enter
    d) After returning all the axes to the home position, turn off the power and
    turn it on again. Return all the axes to the home position and extend the
    measuring unit. Mount a sharp-pointed tool to the spindle and measure the
    tool length in the single block operation. Check to see if the parameters
    have been set correctly.
    Aug 2010
    South Africa
    I am getting an error of -5.5mm in the lengths of tools by this system. This procedure seems good enough for adjustment of X and Y axis values of tool measurement system. But i also need to make some other adjustments so that measured tool length can be corrected. Can you help me in this regard.
    Thanking you
    Sonu
    Aug 2010
    South Africa
    I have adjusted the parameter the system is now measuring correctly. Thanks mantenim
  1. Need Help!- Mazak measuring system tool.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-04-2012, 10:58 PM
  2. Fanuc tool lenght compensation??
    By driftmaster in forum Fanuc
    Last Post: 11-09-2009, 12:00 AM
  3. New In Process Tool Measurement System
    By kcoste in forum Product and Manufacturer Announcements
    Last Post: 10-09-2009, 12:59 AM
  4. Gecko tuning and System Measurement results
    By SMW Precision in forum Industrial Hobbies (Support forum)
    Last Post: 10-01-2007, 11:33 PM
  5. tool lenght question
    By jedioliver in forum Visual Mill
    Last Post: 09-22-2006, 11:27 AM
