Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 03-07-2011, 08:40 PM
crow36 is on a distinguished road
Mazak Powermaster with Mitsubishi L1
Hi all,
Need input from all of u out there regarding a problem we are facing right now with our Mazak lathe machine.
When performing threading, the feed that we commanded should be equal to the pitch we require.
However at this moment, the thread that we get after machining is half the pitch we commmanded in the programme.
For example for 5TPI, we command E0.2(inch) but we will obtain 10TPI.
In order to get 5TPI at this moment, we have to command E0.4
FYI the machine was running ok with E0.2 before this.
Appreciate any input for the sifus out there.
Thank You
Newbie- Mazak Powermaster 1500 mechcanoer Mazak, Mitsubishi, Mazatrol 0 01-26-2011 01:09 AM
Problem- Different size of Mitsubishi Meldas Servo on Mazak 8800 Giampi70 Mazak, Mitsubishi, Mazatrol 3 02-16-2010 07:55 AM
mazak fanuc 6t powermaster Denis13 Mazak, Mitsubishi, Mazatrol 3 03-06-2008 10:56 PM
Mazak/Mitsubishi Servo Jarwalcot Mazak, Mitsubishi, Mazatrol 3 11-03-2006 08:00 AM
mazak mitsubishi spindle drive intermax Mazak, Mitsubishi, Mazatrol 0 11-03-2006 07:56 AM
