Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-28-2011, 04:45 PM
makbari is on a distinguished road
Question pocket maching with long 1/2 tool
anybody knows the best way to machine pocket with 0.3 depth ,
I can not use any big dia tools just 1/2 dia endmill or less and from top of part to top of pocket is 4.5", I tried several way and did not work,
tried several speed and feed and still have problem on corner,
any idea?! thanks
Old 03-01-2011, 10:51 PM
bildoo is on a distinguished road
try pre drilling out the corners, then with such a long tool maybe only step down .03 in depth each pass. then do 2 or more finish passes. i have had good luck with using solid carbide endmills that are long in over all length but only maybe have 1/2 inch of flute then are slightly under cut above the flute. they wont touch the walls above the pocket as much. this wont be a fast process.
Old 03-02-2011, 09:44 PM
Thanks,
I already did that and did not really work,
Old 03-03-2011, 08:42 PM
murrayclair is on a distinguished road
Plunge milling may help
Write drilling/grid pattern and rough the pocket with plunge moves. The number of holes in x and y will determine the stopover, you can tweak this to be optimal. When you call the point drilling cycle and the cnc puts a spot drill and 1/2" drill in just erase the spot drill and change the drill to an end mill.
Old 03-03-2011, 08:52 PM
allsportref is on a distinguished road
How do i post a new Question ?
Old 03-03-2011, 09:18 PM
christinandavid's Avatar
christinandavid is on a distinguished road
You just did...
Old 03-03-2011, 09:29 PM
This is on someones posted question.
Old 03-04-2011, 04:06 AM
Yes I agree it's not too obvious at first glance.
Go to bottom right of screen 'Forum Jump' and select appropriate forum for your question.
At top left of list there should be 'New Thread' icon. Click that then type in your question.
DP
Tool holder pocket drops on its own? Captdave HURCO 1 02-28-2011 10:26 AM
Looking for a suggestion for a multi-pocket-tool. slashmaster Benchtop Machines 4 07-19-2009 05:49 AM
Newbie- Need Tool For Maching Letters and Numbers SDETERS CNC Tooling 5 04-04-2009 07:25 PM
X2 tool entry cuts edge of pocket paulpounds Mastercam 1 03-24-2009 02:01 PM
Ambigious tool pocket Dsny Fadal 5 04-26-2007 07:16 AM
