Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-25-2011, 12:04 PM
Jsheldon is on a distinguished road
re calibrating tool eye on SQT 250MSY
does anyone know the proceedure for recalibrating the tool eye on this machine with out useing the tool eye comp in the tool data?
Old 02-26-2011, 10:08 PM
fizzissist's Avatar
fizzissist is on a distinguished road
Get the Parameter manual out, the settings for the tooleye are in it. Rather than "re-calibrating" it, just adjust the settings for each tip incrementally till it's giving you the correct numbers. Not that hard to do.
Screwing with the tool data to compensate will just cause headaches.
Old 02-28-2011, 12:45 PM
mike marshall is on a distinguished road
tool eye
The parameters that you need to look at depend on the generation of control you have the Matrix uses different parameters than the fusion and below. for fusion B63 is X diameter B61 is for I.D. tools. B61 is adjusted by 1/2 error for B63 teach a tool off a cut dia. Do not move X, write the value down now adjust B63 until the tool eye gives you the same number you just wrote down.
Newbie- Calibrating for holes? DragonSteel Mach Software (ArtSoft software) 0 12-21-2010 11:44 PM
Calibrating your bit for pcb-gcode bsdphk PCB milling 2 12-14-2010 07:50 PM
Help calibrating z-axis sp8zzz2 Calibration & Measurement 0 08-17-2009 08:03 PM
Calibrating NEOLT MX2000 gbarreto Glass, Plastic and Stone 1 01-23-2007 04:05 PM
Calibrating ikkedus Hobby Discussion 0 04-23-2004 10:57 AM
