| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Gents, I am having trouble with a new to me 640m. I will be programming in EIA, and will not be using the mazatrol side of the controller. When I try to teach in the tool offset page it gives me a positve number. Lets say I have the machine at Z 0 in machine position, and I wanted to set an offset there. If I went into the tool offset page, hit teach, it asks me for the distance from tool tip to the table, if I type in 0, it puts a length offset of positive 69." IF I tell it distance from tool to table is 1., it puts in a lenght offset of 68." For some reason, the teach function always add +69." to the lenght offset. What am I missing? If type in the actual machine position, everything works great. Can I calibrate the the "teach" somehow? Thanks in advance, Steve |
Mazatrol calculates tool length based on a parameters. Tool length is the distance from the spindle nose to the table at home position, less the distance from the tool tip to the table at home position. This will be a positive number. The WPC, or in your case work shift, is the distance from the spindle nose to Z zero of your part. This will be a negative number. This is assuming you have a vertical mill. Post more if this does not help. |
| Need Help!- Tool offset problem when running | lifestill | Machines running Mach Software | 4 | 02-25-2010 12:02 PM |
| Fanuc 11TT Tool Offset problem | Bigbear8291 | Fanuc | 0 | 02-10-2009 09:22 AM |
| tool change position on a mazak nexus mill 640m | Denis13 | Mazak, Mitsubishi, Mazatrol | 1 | 02-03-2008 10:15 AM |
| Tool Change Offset problem on 3T control | Andy Kveps | Fanuc | 1 | 02-24-2007 10:36 PM |
| tool offset cancel problem | zoeper | Machine Problems, Solutions , Wireless DNC, serial port | 8 | 04-25-2006 10:46 AM |
