| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
| Hi, I have a problem with my Mazak VQC 15/40. Control, Mazatrol M32 YOM, 1990 In the program, when I put 1mm tool surface speed per revolution, really moves 0.1 mm per revolution. When I turn the fourth axis 1 degree, actually rotates 10 degrees, 5 degrees, rotates 50 degrees and so on. This is also with the program. When I measure the height of the tools with the tool eye (arm type), the measure takes is ten times more than the real. Thanks in advance. |
| There is a parameter (#9 depending on control) that is named UNIT*10. It may be number 9 in user params on your console, if not look for the param by the UNIT*10 name. I think you may have inadvertanly set it to on (highlighted on screen) |
| Thanks. |
| Sorry, The information I sent is for later model of a mazak. Are you using decimal points in your F word i.e. if .1 ipr F.1 How is your 4th axis addressed ( C word) I don't have a lot of information on the M32 but I will continue to look |
| Programmed RS-232 output | ghyman | G-Code Programing | 13 | 07-11-2008 03:53 AM |
| How can I divide surfaces? | Jim Estes | BobCad-Cam | 12 | 01-25-2007 05:29 PM |
| G210 Step Multiply Confusion | RTP_Burnsville | Gecko Drives | 2 | 12-21-2005 11:24 AM |
| Help...How you multiply all drawing dimention by 10 at once ? | Calico | Solidworks | 17 | 08-02-2005 08:49 PM |
| Need PIC programmed | randyf1965 | CNC Wood Router Project Log | 0 | 03-26-2005 05:56 PM |
