Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-20-2011, 11:01 AM
rmarchjr is on a distinguished road
Mazak - Milling spindle repair - Integrex 200SY
Help Please,
Does anyone have a spindle bearing replacement procedure for this or ANY Mazak belt driven milling spindle. 1999 Integrex 200 SY - turret is a typeI 6000rpm unit. I have read elsewhere that these bearings are "field serviceable"
The machine has 2 ring gears which drive the spindle. The backlash between them is huge and causing the noise. The machine hasn't run much in this condition because there is no tooth damage on the gears.
It is likely due to looseness in the rear spindle bearing. I would like to send it out but am very short of cash and need to use the machine ASAP for at least 6-9 months before I could consider big money rebuild.
What is the factory backlash for these gears?
What are the reassembly torque specs?
What is the general dissassembly/reassembly procedure?
Any help would be greatly appreciated.
Rob
rmarchjr@smimetal.com
Old 05-18-2011, 05:37 AM
i.a machinery is on a distinguished road
factory backlash for these gears IS 0.015MM
reassembly torque specs IS 0.030MM
Need Help!- Integrex 200SY X axis backlash KyleEnright Mazak, Mitsubishi, Mazatrol 1 11-06-2010 10:41 AM
Integrex 200SY Question tricmachine General Metalwork Discussion 0 07-02-2009 10:31 AM
Need Help!- INTEGREX 300SY SPINDLE REPAIR CHAD LAWSON Mazak, Mitsubishi, Mazatrol 14 03-13-2009 10:08 PM
Mazak Integrex 100Y Subspindle Milling Mode not working mzbik G-Code Programing 3 01-22-2007 12:59 PM
Using G12.1 Milling Mode on a Mazak Integrex mattclubb Mazak, Mitsubishi, Mazatrol 8 12-22-2006 11:24 PM
