Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-17-2011, 03:52 PM
dudesmpd is on a distinguished road
Citizen L432
I have been getting many servo alarms the last 2 days.Yesterday the machine was getting a S01 servo alarm:PR 0033 S2
Today it was getting the same but the code # was 0042
The secondary spindle seems to be the culprit,as it is getting very hot.The motor turns easily and i dont see anything impeding it.Anyone have any guesses as to why it is heating up so bad-does it have an internal fan?
Old 02-18-2011, 08:54 AM
onthebumper is on a distinguished road
The 33 is an overvoltage in the Spindle drive unit. Alarm 42 is a feedback error. These two alarms are usually unrelated. There usually is a fan on the spindle motor's. Maybe check to see that the fan isn't gummed up with coolant or damaged and not spinning.
Old 02-18-2011, 09:42 AM
girishdk is on a distinguished road
Thumbs up Citizen L432
If you remove the Spindle Motor fan for cleaning, please also check the condition of PLG - Gear, Sensor & the Amp PCB for the PLG. Any oil dust deposit near it, can also create problem.
Depending the on the Spindle motor, the gap between the PLG Gear & Sensor can also be checked.
Best Regards,
Girish
Old 03-14-2011, 01:10 PM
Citizen L432 back spindle motor problems
thank you onthebumber and girishdk for responding.The Citizen tech traced the problem back to a faulty PLG switch.had the switch replaced Friday.Machine ran well all day today,until 2pm...then i got the same S01 servo alarm #33.Not sure what is wrong with this motor.Any suggestions?
Old 03-14-2011, 10:30 PM
If you go to Alarm History page of the Spindle Drive, you can see any other alarm has occurred, just before alarm 33.
This you can judge with the Work Time, in the column adjacent to alarm list.
If there is alarm 42, just before 33, then PLG setting may be disturbed again. When the PLG was replaced,
1) Was the gap between gear/magnet & the sensor was checked through out the complete rotation of gear/magnet?
2) Was there a outside mechanical damage on old PLG or it was internal failure?
Best Regards,
Girish
G12.1 + G16 on Citizen C16 Koalas CNC Swiss Screw Machines 10 09-03-2011 11:36 PM
Citizen FL-42 jayeff1 General Metal Working Machines 0 11-03-2010 02:27 PM
Need Help!- Citizen L20 Tornos100 CNC Swiss Screw Machines 1 04-24-2010 12:52 AM
Need Help!- Citizen L20 humbertocnc2007 CNC Swiss Screw Machines 7 04-16-2010 06:55 AM
Looking at getting used Citizen L20 PoiToi CNC Swiss Screw Machines 5 06-03-2009 08:55 PM
