| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
| Hello Everybody, Machine: Mazak ST40N ATC Control: Mazatrol CAM T-3 Question1: After homing (first X then Z or first Z then X) the following alarm appears; 102 STORED STROKE LIMIT -X What is the reason? Should I change a parameter related to soft limits? Question2: This machine has also a C Axis but it is not servo. There is a gear system that can rotate the chuck min 1°. It has no interpolation with other axes. Now the machine shows; 257 C-AXIS OR SHIFT LS MALFUNCTION And the led on "C-AXIS I/O" key blinks. Can you advise? Question3: Do you have a list that explains all the parameters one by one? Thanks in advance. Best Regards, Mert |
| SOLVED...Mazak QT20 several alarms | SINUMERIKO | Mazak, Mitsubishi, Mazatrol | 0 | 01-08-2010 12:10 PM |
| Mazak alarms strike again | trademarkmachin | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 09-02-2007 03:05 AM |
| Mazak T1 Alarms | mbpp | Mazak, Mitsubishi, Mazatrol | 3 | 06-20-2007 11:27 PM |
| Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem | sting_dot | Mazak, Mitsubishi, Mazatrol | 0 | 05-21-2007 08:20 PM |
