Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-15-2011, 06:35 PM
makbari is on a distinguished road
Problem with long tool Cutting
Hi guys,
anybody know how can I machine a aluminum piece with 0.3 depth pocket?
I have limitation of using just 1/2 dia endmill and it is in down lover of part which is aprox. 5" long, I am using 1/2" dia with 5" shank and DOC is .05
feed is so slow and speed is 6000rpm but I have lots of wibration and tools after a some cuting digging into piece and take my tool out from holder.
any idea what Can I do with this?
Old 02-16-2011, 12:22 AM
rmarchjr is on a distinguished road
I cut 6061 that deep. It really is painful.
When i can, I've had better luck using a c-cutting end mil like a drill.
We have a 1"mill 8"L - it isn't pretty and we need to polish after cutting, but it works and if you control your rapid Z moves, its much faster (and ALOT less noisy) then side cutting.
You may break mills only 1/2" - never tried them that small.
Good Luck, I'd like to hear if you find a better solution.
Problem with cutting tool height to material paulkr SheetCam 1 10-28-2008 01:56 AM
Need Help!- Cutting a Long Piece in Multiple Sections Mr.Chips DIY-CNC Router Table Machines 6 10-19-2008 11:00 AM
cutting keyway on long shaft territorialmill General Metalwork Discussion 13 12-04-2006 09:35 AM
cutting long cut in 1/2 steel plate ZipSnipe General Metalwork Discussion 7 06-09-2006 06:47 AM
Cutting long pieces randyf1965 DIY-CNC Router Table Machines 4 04-26-2006 10:02 PM
