Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-08-2011, 11:15 AM
EliseoMonteverd's Avatar
EliseoMonteverd is on a distinguished road
Mazak measuring system tool.
Hello everyone.
Machine: Mazak VQC 15/40
YOM: 1990
Control: Mazatrol
I have a problem with the measuring system tool.
When I bought the machine was used and started to repair some parts, I had to change the taper bearings and sensors of the measuring tool arm wich it was disabled.
Now it works fine, but do not take real action, it takes real measure multiplied ten times more than real , for example, a tool of 50 mm in height, the machine believes that measures 500 mm in height. How can I solve this?
Old 02-08-2011, 11:20 AM
MTSS Service is on a distinguished road
Tool Measuring Unit
Sounds to me that you may have an issue with a Parameter.
Will get back with you if I can find anything that may be of some help.
Re-check all parameters again would be a good place to start.
Old 02-08-2011, 11:38 AM
Yes, I think you're right.
One of the biggest problems I had, was the loss of parameters, I could fix after searching for hundreds of hours, manuals and information about Mitsubishi and Mazatrol parameters online.
I suspect that may be it is an "R"parameter , but the information I have about these is very poor.
Old 02-11-2011, 06:43 AM
What Type Control
Done some digging, however I need to know which control you have.
Old 02-11-2011, 07:51 AM
Opps, I forgot to mention it is a MAZATROL M32 cnc control.
Old 02-18-2011, 04:02 AM
I have a suspicion that may be the F91 parameter bit 0 and bit 5
Anyone have an idea? Please.
Thank you.
Old 03-04-2012, 09:58 PM
mksurjan is on a distinguished road
mazak
i buy mazak vqc 15/40 cam m2 system. machine sum error 22.somebody help me.please contact me and solv my problem...........my mobile no 09988854432
Need Help!- Setting Mazak Measuring Unit. EliseoMonteverd Mazak, Mitsubishi, Mazatrol 3 06-08-2010 09:32 AM
Need Help!- Y-measuring system defective (Bridgeport Series 2 Interact 4) Robert_Downs Bridgeport and Hardinge Mills 6 08-21-2009 06:20 AM
Need Help!- need help in tool measuring !! ahmed4040 Fanuc 20 07-28-2009 09:31 AM
mazak integrex tool measuring for subspindle Denis13 Mazak, Mitsubishi, Mazatrol 1 05-11-2009 06:24 AM
Z Measuring System Defective A pjeran Bridgeport and Hardinge Mills 11 06-26-2008 10:24 AM
