Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 02-07-2011, 09:03 AM
schmitty9 is on a distinguished road
Mazatrol sub program in EIA
Im trying to run a probe z touch mazatrol sub program from an EIA Pgm. I just need to know if there is a way of running the mazatrol sub without an X and Y location? Its on a Nexus 510c 640 fusion control. No inspection plus or id use that.
Thanks any help would be greatly appreciated
Sent from my DROID2 using Tapatalk
Old 02-07-2011, 01:03 PM
cncnitro's Avatar
cncnitro is on a distinguished road
You can run the Mazatrol probe program as the main program, then run the EIA program as the sub-program. This works for me. If you use the WPC in Mazatrol, you can remove any fixture offsets (G54-G59,G92,ect.) from the EIA program.The EIA program will follow the WPC from Mazatrol program. This would be on an M32 control.
Good Luck!
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
Need Help!- I could REALLY use a sample EIA-ISO program for my Mazatrol Cam T-2! revlimit Mazak, Mitsubishi, Mazatrol 5 07-08-2009 11:32 AM
Mazatrol Sub Program jhersh Mazak, Mitsubishi, Mazatrol 2 12-03-2008 04:09 AM
Restarting in mazatrol program Castle1 Mazak, Mitsubishi, Mazatrol 16 07-03-2007 06:43 PM
Need IEI-ISO sample program for Mazatrol 640 T turkaygeyik Mazak, Mitsubishi, Mazatrol 0 05-29-2007 09:03 AM
