| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hello add this happen back in 2009 and it went away and now its back and need to find out what my be the cause of it its kind of funny how this happens but I can make it happen every time i do this step one open a program and try to use the auto set for the speeds and feeds hit it once and all is fine go back and try it again and Wham out goes the control and the screen show what is in the first pic Parity Error then when i restart it as error 2nd pic 411 Power off during program edit pic 3 is in program at the point before the control shuts off pic 4 is the auto set button for the speed and feeds pic 5 is hardware alarm screen pic 6 is alarm messages and if the machine is not at home 1 it will not find zero again in less you manually move the ball screws to the limit switch in x y & z with the power off because the end coder thinks it at zero is there away to move the servo past zero as where the encoder thinks it is at. manually thanks for your time speed |
| Your program area might be corrupt. Can you back up your programs? If so you might want to try to format the program area. To do this just do an "all erase" under the program button. Take caution though as this will delete all of your programs. |
| I think I got it spent the whole day on and off the phone with mazak service I got it down to the tool file is corrupt is there a way to print out the tool file so I can reinstall by hand I have camware by mazak and been using hyper terminal so the file is in a .txt but it all garbled thanks Speed |
| Need Help!- Fanuc error 998 ROM Parity Error ??? | ED209 | Fanuc | 30 | 04-04-2011 04:19 PM |
| 10T Ram Parity Error | grease | Fanuc | 3 | 01-23-2011 05:22 AM |
| 001 TH PARITY ERROR | jlviloria@gmail | Fanuc | 2 | 10-08-2009 07:26 AM |
| Mazak M32-Parity H Error | compuslave | Mazak, Mitsubishi, Mazatrol | 4 | 02-04-2009 03:25 PM |
| Ram Parity Error | rags | Fanuc | 14 | 12-19-2008 02:03 PM |
