Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-07-2011, 04:24 PM
m_ross18 is on a distinguished road
Mitsubishi Wire EDM SX10 Contact problem
I have a Mitsubishi Wire EDM SX10 that was previously on another site, it was transfered to my site and was installed by ourselves, when we finish we tried to run the machine but we are getting an error, T211 that says 30 sec contact I look on the manual an it says to clear the short-circuit o check for cut workpiece dropping.
Since we havent cut anything, the second one shouldnt be the problem. So the machine should be in a short-cicuit. How can I clear that short? Does anybody knows?
Old 01-09-2011, 12:54 PM
bobwood is on a distinguished road
Checked wire evacuaiton? Any little grounding maybe cause.
Old 01-09-2011, 02:03 PM
Yes I believe is a grounding problem since we install the machine and we have a ground tagless wire that didnt know where it was screwed. and a "G" tagged wire that didnt found where to screw it.
Old 05-01-2011, 11:22 AM
Nocerino is on a distinguished road
Salve, ho comprato una Mitsubishi EDM FX10, (purtroppo senza nessuna garanzia), quando è stata piazzata , mi sono accorto che una scheda era stata completamente privata di tutti i relais, e alcuni componenti, la scheda, è un alimentatore, sulla scheda la sigla è.
AEDA-04-DWC
BY171E614G51 - B.
MITSUBISHI ELECTRIC CORPORATION
Qualcuno mi puo aiutare a trovare un riparatore, o una scheda nuova?
Grazie
Nocerino
Wire EDM Mitsubishi DWC-200 H1 Roswell28 EDM Machines 2 03-10-2009 10:50 PM
Mitsubishi FX1 Wire one4design EDM Machines 3 10-05-2008 01:37 PM
Need Help!- MITSUBISHI SX10 SERIES(SEND DATA BY RS-232C) Alfredo Lugo Mazak, Mitsubishi, Mazatrol 7 08-10-2008 09:21 AM
Mitsubishi DWC-110H A Wire EDM Floppy Problem tjurek Machine Problems, Solutions , Wireless DNC, serial port 5 10-11-2007 07:08 AM
Mitsubishi H110 Wedm Wire Problem osomaker CNC Plasma and Waterjet Machines 1 12-11-2006 12:23 PM
