Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 01-04-2011, 04:55 PM
Scottjit is on a distinguished road
Exclamation SL 50 turret out in X-axis
I have a Mazak SL50 that they crashed so hard they knocked the turret out in the X-axis plane. We adjusted the turret rotation on center but when you sweep the face of the turret it is out .015 on one side. I know on a Mori there is push pull blocks to adjust this. There is no blocks and I need to move it more than the bolt hole will allow. What can I do adjust gib ????
Old 01-04-2011, 06:01 PM
cncserveng is on a distinguished road
are you absolutley sure the turret isn't bolted to the carriage ?
Because usually you have to get the turret square to the X/Z axis before adjusting to spindle center line. There could be some taper pins in the turret disk and/ or body and they could be bent, check and replace with straight ones, but always remove the turret disk ones again after tightening, or you may have an even harder collision next time if the disk cant move during a bump.
Also, you may not get the disk off if you need to with bent pins.
Old 01-04-2011, 06:46 PM
Yes the Turret is bolted to the carriage. There are two pins in it. When we take them out (the pins) we only get about .008-.010 movement. I need .015 so we need .005 more. This is why we thought of turning down the bolts.
Old 01-05-2011, 01:19 PM
If the x axis is a slant bed, you may need to lift the turret body a little to get enough movement. But, if things have been strained you may need to adjust the bolts or open up the bolt holes one by one to get the adjustment. when you have corrected it in X/ Z and disk (radially) to the spindle, lock it up and ream the pin holes to fit new "oversized" pins.
Old 01-05-2011, 02:01 PM
underthetire is on a distinguished road
If it's like our big Mazak, it's on linear guides. You may have shoved the whole thing on the guide packs.
Old 01-13-2011, 06:34 PM
I aligne the turret today. It was out .015 in x-axis to the spindle (running an indicator on the face of the turret. loosen the 8 M14 bolts and removed the taper pin. hooked up the 2T crain on the turret and pulled. It came in within +.0003 no problem.
Thanks for all the help.
okuma twin turret axis flip? fishy steve Okuma 12 11-11-2010 07:35 AM
Need Help!- Hardinge Superslant SB3 GN 3 Axis Lower Turret LMartin Hardinge Lathes 18 09-17-2010 09:42 AM
Tool Turret Fault Alarm on TL-1 with no Turret? Edster Haas Lathes 10 02-08-2010 08:35 AM
3rd axis turret need grid Shift ! but how ? mte.jalal Daewoo/Doosan 5 09-02-2009 10:26 AM
Mori lather Zt1500 18i : turret Y-axis homing teal854t Fanuc 1 01-11-2009 03:10 PM
