| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Hi, We have a Mazak A16 with X,Z and C axis (full). The machine is equiped with a T+ control. So drilling and tapping bolt circle holes is no problem BUT has anyone managed to chamfer the holes prior to tapping? I know that I could do this with my CAM software but I wanted to see if it could be done either with Mazatrol or by using a macro. Anyone done this? |
| Chamfering as in plunge in and out? That can be done in a drill cycle or boring cycle--just have to feed to a much shallower depth than with drilling. This will be on its own process. Just copy the drill cycle and make the depth shallower using a different tool. If you mean interpolating the chamfer around the holes, that takes a lot more programming, but it can be done. |
| ISO G-code for Mazatrol + Plus if you have that option. It is in your manual if you have one. G72.1 X...Y...Z...R...P...Q... X,Y,Z,P,R same as any other drilling cycle P=overlap amount Q=radius of hole to chamfer minus radius of cutting edge of your tool |
| I am not familiar with Mazak but what I do is program the center drill deep enough to leave a chamfer. It's not a 45 chamfer but it does break the corner and gives a good start for the tap. For example on a 3/8 hole use a 7/16 or 1/2 center drill and program it to .400" deep. It generates @ .400" diameter chamfer a little bigger than the 3/8 threads. |
| if you are using Mazatrol. When you write the unit for tapping. it should ask you how much of a chamfer you want around the hole. then it is just discribing the tool properly for the machine. for larger holes. there is a unit for "chamfer in" . then you just tell it the canter position of the hole, and the Radious of the hole. |
| i run a 410a and variaxis i just use circular mill unit to do my chamfers instead of chamfer in cos it can interfere with the hole size for some reason ! i just descride a standard 10mm carbire 90deg spot in machine as 10m but put a diameter of 2mm in the tool table and program 2mm deep to what ever rad u want around hole then adjust z depth to suit size of chamfer/break edge ! |
| Chamfering Help Please!! | Randy727 | Solidworks | 3 | 07-22-2010 05:27 PM |
| Just IN- Need help chamfering holes in sst sheet | Vretsam | General Business Practices and Pricing | 7 | 11-17-2009 05:58 PM |
| Chamfering?? | BulleTxMagneT | Dolphin CADCAM | 2 | 09-14-2007 10:47 PM |
| Need help in chamfering | abcdef | General Metalwork Discussion | 15 | 04-24-2007 06:34 PM |
| chamfering | Mortek | General Metal Working Machines | 4 | 02-06-2004 09:24 PM |
