| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
A client has a Mazatrol T-2 that displays the following error on startup "20 NMI Emergency Stop". Also the power ON and power OFF LEDs next to each button are both ON when the power ON button is pressed. To cut a long story short it appears as if the PLC program is not being executed. e.g. According to the PLC program the PON relay (PLC output Y024, memory address H044.4) should turn on as soon as the operators power on button is pressed. This does not happen. The relay can be turned on manually via the diagnostics page (setting bit 4 of H044). When this happens the error message clears however this does not solve the problem. Has anyone experienced the above symptoms ? And what could the cause be ? Jeff. |
| "20 NMI Emergency Stop" will come up if E-stop is pressed in. I'm guessing it's not--right? Are there any other alarms on the Diagnostics page? Inside the back panel electrical door on my QT, there is several small, black circuit breakers (near the clear plastic relays) that look about the size of a regular home light switch. If there is a fault, these breakers can trip giving this alarm. They are real sensitive. I have tripped them by merely brushing up against them. Alarms can also show up if he lost any parameters. Are there any asterisks (*) in the parameters? |
| Check out this thread, Need Help! NMI 20 Emergency Stop Alarm - CNCzone.com-The Largest Machinist Community on the net! This concerns an M2 powered mill but I would think it would be the same or at least similar for the T2. Good Luck! |
| You are all giving good advise, but I would look and see if all the start preconditions have been made. You should be able to follow the electrical drawing and see which 24v input is missing. Or, if you have a ladder logic hard copy, use the "I/F Check" page to check the input and outputs. This error i think is the Mitsubishi "020 emergency" caused by an external problem. (Mazatrol is Mitsubishi Meldas hardware) Start conditions may include spindle and axis drive ready signals, also air pressure etc; |
#11
| The FX715 board has 6 EPROMs on it. The ladder logic for the SB.M (H044.4) output which controls the PON relay is: PCRUN PCRDY H09F.7 H09F.3 ---||---|----------------------------------------( )-----| PCRUN | H09F.7 | ---|/|--- . . . Several pages of ladder logic . . PCRDY SB.M H09F.3 H044.4 ---||----------------------------------------------( )-----| So you can see that when the top rung is executed it does not matter what condition the PCRUN relay is in PCRDY will always turn on. The second rung shown will then simply turn on SB.M (NC REDY) and this output turns on the PON relay. If you look at the electrical diagram one of the operations of the PON relay is to turn off the NC power off LED on the operating panel. This is NOT happening for this machine. Can someone check the state of the above relays for there machine (T-2). I still believe the PLC program is not being executed. There must be some other hardware signal inhibiting the FX715 board from operating, however all the LEDs on it appear to be showing a normal state. I have checked the 7 emergency stop conditions e.g. thermal trip, air pressure, hydraulic pressure etc. all OK. |
| need help - Mazak QT15 " bUS ERROR AT OR NEAR $004C0D96" | VENKATESH REDDY | Mazak, Mitsubishi, Mazatrol | 0 | 08-16-2010 04:40 AM |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| "J" head type "millport"(tiwan,1980) clutch | marksbug | Bridgeport and Hardinge Mills | 1 | 08-17-2009 10:48 AM |
| Problem- "Soft Stop" error MPC6515 | KPBadger | Laser Engraving & Cutting Machines | 3 | 02-25-2009 01:37 PM |
| mazak t1 universal "error 124 n" | dohcom | Mazak, Mitsubishi, Mazatrol | 0 | 11-23-2006 07:25 AM |
