Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-21-2010, 03:30 PM
pocok is on a distinguished road
Mazatrol T_PLUS no display/no start
I have a Mazatrol T-PLUS which after a long weekend won't start up properly.
Turning machine ON_OFF a couple of times it solved the problem but like to fix it if i can. Problem when is dead :
No display and no ready light is coming ON. Red light on QX722 board which piggybacks the QX141-1 CPU.
Battery accessible from front of the controller shows 3.009 VDC (OK)
Are there more batteries in this controller?
Any suggestions? Does anyone has a complete schematics for the controller:QTL25L NC M515LWY5397
Old 12-22-2010, 06:30 AM
Can I take out the power supply module for servicing, without loosing my programs and reference ?
Old 12-22-2010, 08:11 AM
onthebumper is on a distinguished road
You can pull the power supply out for a short period of time (less then 30 minutes) and you should retain all of your data. Beyond that it is a gamble if you lose data or not.
Old 12-22-2010, 08:51 AM
mantenim's Avatar
mantenim is on a distinguished road
Yes, no problem.
Old 02-02-2012, 04:38 PM
cncpiotr is on a distinguished road
Hello
I have the same problem.
QT-20 machine Mazatrol T-Plus
What was the cause of your problem?
Does anyone have a list of parameters?
What is the procedure re-install the control?
Old 02-03-2012, 10:26 AM
reply to cncpiotr
sorry I left the company before got fixed
Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english tuanpq Mazak, Mitsubishi, Mazatrol 21 01-21-2012 07:33 PM
Need Help!- Mazatrol M-32 will not start-up Bullet605 Mazak, Mitsubishi, Mazatrol 8 05-27-2011 05:30 AM
Need Help!- Sm1 well versed with mazatrol 640m or atleast ne mazatrol naren1608 Mazak, Mitsubishi, Mazatrol 0 03-22-2010 05:29 AM
Need Help!- No Display on Start up jimmck Haas Mills 4 10-29-2009 03:56 PM
Arrow 750 Failed to start when I Push start Bottom in fornt of control ! mte.jalal Cincinnati CNC 4 01-06-2009 10:20 AM
