Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-21-2010, 07:00 AM
EliseoMonteverd's Avatar
EliseoMonteverd is on a distinguished road
Mazatrol M32 programming examples
Hi folks, I have a VQC 15/40 vertical MC with 4șth axis an M-32 controller.
Can someone send me some simple programming examples for Mazatrol and EIA/ISO, please?
Better still if it contains examples with index table.
Thanks in advance.
Last edited by EliseoMonteverd; 12-21-2010 at 07:06 AM. Reason: I forgot to mention something.
Old 12-21-2010, 08:25 AM
ronald86 is on a distinguished road
hola atodos .soy nuevo en este foro espero intercambiar muchas ideas con los demas.
Old 12-21-2010, 10:51 AM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
Here is a sample program and sample post process.
Hope this helps.
Good Luck~!
I'll work on that 4th axis in a bit,...busy right now
Old 12-22-2010, 03:33 AM
Hope this helps.
Good Luck~!
Thank you for your time.
Anyone out there like Mazatrol programming? kappullen Mazak, Mitsubishi, Mazatrol 2 11-22-2009 09:57 AM
Programming Mazatrol T1 diz Mazak, Mitsubishi, Mazatrol 16 12-19-2008 05:17 AM
Mazatrol T-4 programming help machinist360 Mazak, Mitsubishi, Mazatrol 0 08-26-2008 09:39 PM
Need Help!- Mazatrol programming T-plus Bobesmo Mazak, Mitsubishi, Mazatrol 13 07-30-2008 06:18 PM
Programming Mazatrol T-Plus toolmach General Metalwork Discussion 1 04-02-2007 05:39 PM
