Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-16-2010, 04:53 PM
southern cnc is on a distinguished road
Maztrol - CNCNet program transfer?
Hello, has anyone had success getting Mazatrol M-2, M-32, or T-2 to upload and download using CNCNet DNC? With the M-2, we can get it to transfer to the laptop, but when trying to load the same program, it only loads a little bit and alarms. I'm not sure the transfer to the laptop is correct either.
Thanks for any help.
Southern CNC
Old 01-26-2011, 04:20 PM
I guess not.
I take that as a no. I thought since it was free, someone would be using it for Mazatrol.
Old 02-28-2011, 03:00 PM
rusty5228301 is on a distinguished road
Hello,I use this software with no probs on vtc 20 b (mazatrol m plus) what message do u get when trying to send a program? what settings do u use on the machine side (user g parameters)?
Old 03-03-2011, 03:45 PM
Thanks for the reply Rusty.
My control is the Mazatrol M-2. Could you tell me the pinouts of the cable
you are using? I've tried the cable that the CMT (the blue box with floppy drive) uses, with no luck.
It sends to the computer, but when I try to upload the saved file to the machine, it only sends a few bytes, then stops. I am not sure that what is sent to the computer is correct.
Could you also send your parameter settings? I can make the changes between the M-plus and M-2 controls. I would also like to get it working with
a lathe that has the T-2 control.
I surely do appreciate the help. If I can get this working, it will save
a lot of time.
Old 03-07-2011, 01:28 AM
mazak-user is on a distinguished road
RS232
a lot of time.
look at this pdf.
best regards
mazak-user
Old 03-07-2011, 09:48 AM
Thanks for the service bulletin, mazak-user. Are the other service bulletins available online somewhere?
I'll give this a try with the CNCnet software.
Southern CNC
Old 03-09-2011, 02:35 AM
Hallo!
Sorry no.
best regards
mazak-user
I noticed a Free DNC program download on the main page for CNCzone called CNCnet DNC Rocko1 Haas Mills 4 03-22-2012 11:56 PM
Mazak Program Transfer Mark18969 Mazak, Mitsubishi, Mazatrol 14 11-09-2009 04:06 PM
program transfer between CNC and PC sinha_nsit Fanuc 10 08-01-2009 05:03 AM
NC Transfer Program JamesBond General CAM Discussion 69 04-07-2009 06:40 PM
transfer of program Dar Bridgeport and Hardinge Mills 10 09-13-2007 09:43 PM
