Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-14-2010, 08:57 PM
Jfrahm is on a distinguished road
milling parameters for t2 controller
I bought two slant 30 atc lathes a couple of years ago one has T3 controller one has T2. Now I got parameters for T3 and its been up and running for awhile now. Now here's the rub I got the parameters from mazak for the T3 but according to mazak the machine with the T2 has a fanuc controller according to the serial number and they basiclly told me there was nothing they could do. So I loaded the T3 parameters in to the T2 but it has 205 milling conroller alarm so does any body Know what parameter will turn off the milling
Old 12-18-2010, 02:23 AM
Philabuster is on a distinguished road
I think the T2 will have fewer 1's in the OP parameters for less options like milling. I believe somewhere in the first few OP parameters will turn off your milling. I had an issue with my friend's newer QT10N T3 than mine and his OP 4 parameters (milling drive 205 alarm) were slightly different because he did not have a separate spindle drive. His OP 4 needed 1100 0000 and mine was 0000 0000.
I do not have my book here though. Try making OP 1 or OP 3 all zeros. I do know that when the parameters get dumped, my C-axis is no longer on the screen until I reload the parameters.
Make a change to the parameters, then turn off power, then restart. Some parameters like the OP parameters are only effective upon machine start-up.
Here is a JPG of my QT10N T-3 parameters for reference.
Name:	QT10N ATC_MC Parameters 3.jpg‎
Need Parameters Mazatrol T1 Controller. weblogictech Mazak, Mitsubishi, Mazatrol 23 07-04-2011 04:34 PM
Need Help!- Aciera F 450 APM Milling Machine lost NC parameters IMS General Metal Working Machines 0 11-23-2009 02:23 PM
milling parameters rishijain Diemaking and Diecutting 1 11-21-2008 09:17 AM
Editing parameters on Oi-MC controller rab Fanuc 4 12-06-2007 07:09 AM
Fanuc 0P-C controller RS232 Parameters scottsr60 Fanuc 5 01-02-2007 07:13 AM
