Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-09-2010, 06:29 AM
cSpampinato is on a distinguished road
Mazak Horizontal Mill Magazine Problems
As soon as I turn on the mill, and the hydraulic pump begins working, an alarm comes up that reads "Magazine Driver Malf. 212". We cannot get the magazine to move at all. Not even with the manual controls. We just got this mill from an auction, so we don't realy know if the machine is fully functional. The controlls on the machine are Mazatrol M-32 if that helps any. All help is greatly appreciated.
Old 12-15-2010, 12:10 PM
You guys suck. Can't ever get any help!
Old 12-20-2010, 07:42 AM
padameng is on a distinguished road
Have you checked the drive is it healthy most likely something is wrong with the servo drive of the magazine
Old 12-20-2010, 05:35 PM
Micwanho is on a distinguished road
Alarm 212
Alarm 212 is sort of a generic Mazak alarm. It is telling you to go look at the magazine drive unit and see what the problem really is. On a M-32 control I have seen both Yaskawa drive units and Mazak Justpoint drive units. Each one is different in how it displays alarms. Could be just led's or a seven segment display. It should be located in your electrical cabinet with the other servo drives, but it will look completely different.
If we knew what model of machine you have it would help a lot. It might be that you just need to zero return the magazine. On some machines there is a magazine/atc zero return toggle switch in the electrical cabinet. Flip the switch and call up tool #1. On other machines it is a m-code, M-68 that is needed. Again all info you can provide will help. How many tools in mag? Is it CAT 40? Can you determine what type of magazine driver you have?
Old 12-21-2010, 10:03 AM
pontiacg5 is on a distinguished road
On a FJV we've got here you have to zero the ATC before the machine will run.
The alarm, if you don't zero the changer, says something along the lines of "Magazine return search unfinished" though.
That machine does have a M+ controller though, but it's also the only mill that we have that requires you to zero the changer. (We have an identical FJV that doesn't, go figure!)
Either way, to zero the changer on a M+ you just press the machine button, then the ATC soft key, and then the "mag zero return" soft key. I guess it's worth a shot!
Mori horizontal spindle problems cullipj Mori Mills 17 01-27-2012 09:48 AM
Need Help!- Mazak VTC 41M Zero Tool Magazine cuttingcnc Mazak, Mitsubishi, Mazatrol 0 12-06-2010 04:27 PM
Problem- Mazak -MTV515- Magazine-M32B yepingapple Mazak, Mitsubishi, Mazatrol 0 10-15-2009 01:13 AM
OKK horizontal cnc mill HMA460 bum1033 General CNC (Mill and Lathe) Control Software (NC) 1 05-20-2008 08:18 PM
Help with Horizontal Mill Programming MAX RPM Mechanical Calculations/Engineering Design 8 06-20-2006 10:18 PM
