Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-07-2010, 05:06 AM
sonu is on a distinguished road
Error in table position for z axis, Mazak FH6800
I performed ABS posotion repair in MRJ2 unit for pallet changer in Mazak FH6800 machining center. Now my table position for z axis is changed. Pls provide guidance how to rectify the error in position of table.
Old 12-14-2010, 09:14 AM
mantenim's Avatar
mantenim is on a distinguished road
open the MRJ2 software.
open the parameter display
read the parameter
open test operation display
(in mazatrol unclamp table)
in test operation move the table in the correct posicion.
for the new zero, select (absolute position inicial set)
push origin set
push normal rot
the table will move and stop. and it takes the new zero.
(clamp table)
an move the table at zero point in MDI.
review the Zero.
Old 12-15-2010, 03:46 AM
Thanks mantenim, i will perform the suggested rectification and check.
Old 12-21-2010, 12:08 AM
Dear mantenim, the procedure given by you seems to be for position of table rotation i.e. B axis while i need for position of Z axis. you can help in this regard. Thanks
Problem- mazak fh6800 atc driver alarm waseem sajjad Mazak, Mitsubishi, Mazatrol 3 07-07-2010 07:46 AM
Need Help!- Mazak FH6800 spartus333 Mazak, Mitsubishi, Mazatrol 4 03-31-2010 01:07 PM
OLD UHU POSITION ERROR dfv UHU Servo Controllers 2 03-22-2010 12:16 PM
Mazak M2 home position jjsells Mazak, Mitsubishi, Mazatrol 0 02-02-2009 05:35 PM
Mazak Integrex 1060v8 c axis position errors Bushman Mazak, Mitsubishi, Mazatrol 0 11-29-2007 03:28 PM
