Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 12-06-2010, 08:13 AM
pontiacg5 is on a distinguished road
Replacement Mazak monitor
I'm considering replacing the monitor in an old M2 mill with a LCD monitor, from what I've read the old monitor uses RGBHV but most LCD monitors use VGA or DVI. There are RGBHV to VGA and RGB to DVI adaptors but some searching on the forum here led me to some results that mentioned something about the refresh rates not matching up.
Does anyone have any more info on what exactly the Mazak M2 controller is using as far as input to the monitor? I know there are companies out there that sell replacement CRT monitors but frankly the prices are absolutely ridiculous for what they are. (supply and demand I guess?)
Thanks!
Old 12-21-2010, 12:45 PM
pocok is on a distinguished road
The RGBHV = VGA. The signal cable is a 15 pin DIN connector, google the pin outs.
I suggest to go to walmart and buy a GPX 13 inch hdtv monitor for $100.( model number TE1380B ) I use this tv to go to service machines. It has versatile inputs and in VGA mode I think would fit your needs.
Good luck, it is worth to try. Let me know
Old 12-21-2010, 03:48 PM
From what I've read the horizontal sync refresh rate on the Mazak won't match what most VGA LCD monitors use so you have to use some sort of converter box...
At least that's what I've read. If that TV is only 100 bucks I might just give it a shot just for fun.
Thanks!
Old 12-24-2010, 03:17 PM
If that's the case try this circuit
Video Converters - CGA/EGA/YUV to VGA Arcade HD-Converter PCB (GBS-8220) - JAMMABOARDS.COM - JAMMA Coin-Op Arcade Game Parts - CGA/EGA/YUV to VGA Arcade Converter PCB (GBS-8220)
If this can't handle it nothing will !
Joe
Old 03-19-2012, 09:04 PM
machinist360's Avatar
machinist360 is on a distinguished road
Did this ever work for anyone?
"Fire is cool" -Beavis
Old 03-19-2012, 09:09 PM
hhm2r7287 is on a distinguished road
Old 03-21-2012, 02:36 AM
gridley51 is on a distinguished road
The horizontal synch rate is only about 14 on the Mazak.Most modern screens don`t come much below 28.
I have successfully used these 12.1" screens to replace M2/T2 monitors.Just need to change the plug and it goes straight in.
12.1 Inch CGA EGA VGA to SVGA LCD Panel
Heidenhain BE211B Monitor replacement ichudov Bridgeport and Hardinge Mills 0 02-24-2010 11:02 AM
Bridgeport EZ-TRAK LCD replacement Monitor RADAPG1 Product Announcements & Manufacturer News 0 10-26-2009 09:42 AM
Mazak monitor gridley51 Mazak, Mitsubishi, Mazatrol 2 08-30-2007 01:53 PM
Mazak T1 Monitor bean79au Mazak, Mitsubishi, Mazatrol 4 08-21-2007 12:32 AM
Need a monitor replacement - Heidenhain TNC 2500 litestat12 Bridgeport and Hardinge Mills 12 05-01-2007 05:03 AM
