Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol
Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here!
Old 11-23-2010, 01:05 PM
hamidrez is on a distinguished road
MDS-B-CVS-260 Alarm 0077
Hello
We have got a cnc machine in our company and there are a spindle driver MDS-B-CVS-260 in this machine .
Unfortunately the machine has stopped because of this alarm:
S01 SERVO ALARM:PR 0077
So pleeaaaaaasssssssseeeeee help me to solve it.
Thank you in advance.
Old 11-23-2010, 09:38 PM
interruptedz is on a distinguished road
you should check the fan first, then the supply voltage, chances are the power supply is already defective.
Old 11-24-2010, 04:20 AM
Thank you for your reply Sir
I have already checked the fan and it works properly.
I know this alarm is about overheating in powersupply but I am wondering is there any parameter in the spindle driver to change it or not?
In addition ,the powersupply has got a flashing "n" on its display.
Please send me your advice
Thank you
Old 11-25-2010, 11:59 AM
mantenim's Avatar
mantenim is on a distinguished road
Thank you
in the power supply, remove the power module and change the thermal paste, and reassemble the power module in the power supply
if that fails change the power module in the power supply
Old 11-29-2010, 03:28 AM
Thank you for your reply,
But unfortunately I don't know what exactly is this"Thermal paste".
Could you please give me any hint in this respect.
Thank you Sir.
Old 11-29-2010, 08:45 AM
mantenim's Avatar
Thank you Sir.
thermal paste = heat sink compound
NEED HEELP ALARM #414 Y AXIS SERVO ALARM? PICMAN Fanuc 6 04-29-2011 05:20 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
Alarm 409-servo alarm- z axis torque alm jessebpm Hyundai Kia machine 3 06-14-2010 07:45 PM
ALARM shuttle drawbar alarm haas timmydabull Haas Mills 27 10-30-2009 08:27 PM
Need Help!- DAEWOO 8 Steady rest pressure alarm, External feed hold alarm doubleeagle Daewoo/Doosan 4 06-12-2009 03:15 PM
