| Mazak, Mitsubishi, Mazatrol Discuss Mazak, Mitsubishi and Mazatrol systems here! |
Not sure about Matrix, as I've not used it, but on all the older controls the only way to do it is to use an ISO sub-program. |
| Mr. Mazak; The question was for milling the thread, not using a tap. And here Gibbs got a fine process of milling conical threads. ![]() --And for the record; klzz is a co-worker and long time friend of mine, so the "moron"-part was just for fun hehe |
| You don't understand the planetary tapping cycle. It is a thread MILLING cycle. Set up your thread mill as a floating tap and set the actual diameter in the Tool Data page. The thread mill you use will feed down to the depth you programmed (control the down feed in the sequence line) arc in to the wall 1/4 turn in, make one revolution around (like a planet) and arc out 1/4 turn all while moving the Z using the pitch in the sequence line. I have attached a sample program. |
| Mr. Mazak; Ok, my bad. Thought you meant tapping since you wrote tap and not thread mill. But this will still not help klzz, as he wants the threadmill to move conical and follow the threads angle. Say you have a mill with only one set of tooths that you have to use to make a conical thread, then you will need a program that moves conical. We use the planet cycle metod for thread milling here all the time, also on npt-threads using conical mills. But tough we use conical mills for npt-threads, we still want the threadmill to move conical as this will be more correct for our products meant for high pressure in the oil industry. Bot me and klzz used to do this where we worked before, using macros. But since we started here we`ve only used planet cycle. One sollution is to make subprogram with gibbs for the npt-threads we use most common. klzz asked this question before we knew that we could do this with Gibbs. But thanks for answers anyway
__________________ Best regards Hans Olav Seljeskog |
| Mazatrol 640M/ Matrix Post | BryCAM | Mazak, Mitsubishi, Mazatrol | 1 | 04-27-2012 01:30 PM |
| Mazatrol Matrix Nexus speed questions | neurosis | Mazak, Mitsubishi, Mazatrol | 10 | 12-29-2010 07:18 AM |
| Need Help!- Mazak integrex 200-IV mazatrol matrix alarm 1281 | bor32 | Mazak, Mitsubishi, Mazatrol | 0 | 09-02-2010 01:59 AM |
| Mazatrol Matrix | wawankot | Mazak, Mitsubishi, Mazatrol | 6 | 04-01-2009 01:16 PM |
| Need Help!- Matrix Mazatrol Tornado Mill Unit | LarryA | Mazak, Mitsubishi, Mazatrol | 3 | 03-23-2008 01:01 PM |
